AutoCAD Plant 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: AutoCAD Plant 3D Catalog Builder (Beta) is available now
- Highlight
- Email to a Friend
Win 7 prof 64bit, work correctly
Yury Bogdanov
ASIDEK(Grupo CT)
Barcelona (Spain)
- Highlight
- Email to a Friend
To install it, you need to unRar into your AP3D intalled folder, (Autocad Plant 3D english) and run it...
and Voila!..it´s works..!
- Highlight
- Email to a Friend
In the case when I go to set the dimensions in the excel, in the column of OD (out diameter) I write the values in mm, for example:
88,9 - for pipe DN80
114,3 - for pipe DN100
When I export this excel sheet from Catalog Builder to one exist catalog the program don't recognize "coma", the OD result diameters are:
889
1143
Yury Bogdanov
ASIDEK(Grupo CT)
Barcelona (Spain)
- Highlight
- Email to a Friend
Currently, The Beta is only support period (".")delimiter.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Plant Solutions - AEC
Autodesk, Inc.
- Highlight
- Email to a Friend
rajsekarpillai escribió:Hi,
Thanks & Regards,
I was prove with "." delimiter and it don't work too.
Yury Bogdanov
ASIDEK(Grupo CT)
Barcelona (Spain)
- Highlight
- Email to a Friend
I think this could be the computer delimiter issue.
Go to Control panel -> Region and Language -> click the Formats tab -> click the additional settings button -> change the “list separator” to “.”Instead of comma.
If this doesn’t work, please attach your excel file and I will try at my end.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Autodesk, Inc.
- Highlight
- Email to a Friend
This is the excel
Yury Bogdanov
ASIDEK(Grupo CT)
Barcelona (Spain)
- Highlight
- Email to a Friend
When I try to start AutoCADPlant3DCatalogBuilder.exe Windows 7 64 German tells me that the program doesn't work anymore. The HowTo actually doesn't mention this AutoCADPlant3DCatalogBuilder.exe. So I'm wondering if it's needed at all.
Thanks for hints
Carsten
- Highlight
- Email to a Friend
When the template are created with all objects of new catalog, and we create the excel, after one hour of defined the geometry of objects in excel I find that my nipple have all connection points together...( is imposible to define the each connection point separatly, one PL another FL for example). Which is the solution? Change the config in Catalog Builder and turn to create excel (purgeing my one hour of work)? Is posible to change only this object in CatalogBuilder and others sheets of excel don't touch, because have all geometry of objects defined.
Yury Bogdanov
ASIDEK(Grupo CT)
Barcelona (Spain)
- Highlight
- Email to a Friend
Hello Eileen,
I dowloaded Catalog Builder and followed all the steps in the accompanying docx file.
I was unable to run the testacpscript lisp program as mentioned in point 4 of the docx. This file does not appear to be available anywhere I have searched.
Point 5 e in the docx reads:
"Save the image to custom script folder. When user request the custom script images by image API, the image API will scan the custom script folder to fetch the images which meet requirement."
Please elaborate on "request the custom script images by image API".
Where does in fact TestScript component get accessed from? Plant3D? Spec Editor?
I feel I am missing some background on how and where I can put Catalog Builder to use.
