• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Member
    Accepted Solution
    AutoCAD Plant 3D 2013 Off-Page Connector Hotfix Readme
    426 Views, 3 Replies
    10-08-2012 11:33 AM
    Just installed this hotfix as per the Readme instructions. Now when I open my Plant 3d software It pops me the following error message:
    Failed to Load Project File.
    I've tried different project files, including the default one, and get the same error message. I tohught the dlls could somewhere be stuck in Wondws memory, so I shutdwon the computer and tried again. Still the same result.
    Any Ideas?
    Jeff
    Please use plain text.
    Product Support
    Re: AutoCAD Plant 3D 2013 Off-Page Connector Hotfix Readme
    10-09-2012 02:36 PM in reply to: jlippincott
    Try this:
    Close out of Plant 3D and any other AutoCAD related tools. Run the following utility.
    C:\Program Files\Autodesk\AutoCAD Plant 3D 2013 - English\PnPLocalDataCachePurger.exe
    Let me know if this works
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    Quentin Contreras
    Support Specialist
    Product Support
    Autodesk, Inc.
    Product Support
    10-12-2012 04:55 PM in reply to: jlippincott
    Have you been able to resolve your problem yet?
    Quentin Contreras
    Support Specialist
    Product Support
    Autodesk, Inc.
    Product Support
    10-15-2012 02:25 PM in reply to: jlippincott
    It appears the built in extraction tools from Win7 is causing the problem.
    To fix this follow the steps below:
    First:
    Restore your system by copying back the original DLLs (If your DLLs were not backed up, use the DLLs in the attached ZIP file)
    Verify that the project manager is working
    Second:
    Open the zipfile from the hotfix (http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19117194&linkID=14116968) using WinZip specifically, and use WinZip to extract the DLLs to a temporary location
    Copy the DLLs into your installation.
    Verify that the project manager is working.
    Quentin Contreras
    Support Specialist
    Product Support
    Autodesk, Inc.
