• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    berucheva
    Annotation on Ortho dwgs
    254 Views, 1 Replies
    09-26-2012 12:08 AM
    I created new annotation  on ortho dwg - Elevation. All is ok, but there is one issue. After opening dialog Project Setup and open dialog Edit annotation my annotation have been moved (after.jpg)
    Please use plain text.
    Member
    Re: Annotation on Ortho dwgs
    09-26-2012 08:02 AM in reply to: berucheva
    Hello berucheva, Hello Plant discussion Group!
    I am noticing the same issue like you. When creating annotaions with additional geometry to Plant 3D attributes it causes this problem. Only thing that worked for me is setting the basepoint of the Plant 3D attribute to "middle-center" and 0,0,0 WITHOUT any additional geometry.
    If i add geometry or move the attribute basepoint from 0,0,0 to another location it´s changing the location everytime you enter the block editor of ANY annotaion block into your setup even without making changes to them.
    It might be someone out there who got the solutions for this problem/bug
    best regards
