AutoCAD Plant 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
An xref has been moved to an unsupporte d location
- Highlight
- Email to a Friend
I have 5 xrefs, of 5 aquaculture systems in a row. these 5 systems are repeated 3 times.
x x x
x x x
x x x
x x x
x x x
So I xref'd them into a floor plan, then if I copy or attempted to xref more in away from 0,0,0 I get the error message
"An xref has been moved to an unsupported location"
What are the ramifications of this? The 3 overall systems are not interconnected.
"Do or do not... there is no try"
Master Yoda.
Re: An xref has been moved to an unsupporte d location
- Highlight
- Email to a Friend
In previous versions it caused connection problems with piping but I though 2012 had solved that. I have not tried it because I always make sure xrefs are inserted at 0,0,0.
I, personally, would have used either 15 xrefs all inserted at 0,0,0 or done the copy in the original file so that you have 5 xrefs with 3 systems in each. That way you will not have any issues with pipe connections and you also will not end up with the annoying error message.
Other than that I am not sure what further implications there are.
- Highlight
- Email to a Friend
Yeah what I may end up doing is finishing the original 5 xrefs, then just copy them to new files giving me the 15 then I can insert them all at 0,0
Master Yoda.
- Highlight
- Email to a Friend
Xrefs need to be inserted at 0,0,0 in order to maintain intelligent piping connection across the Xrefs. That's the reason for the warning message.
If you're using a floor plan or plot plan, use a common take off point and align that to 0,0,0. Then all of your Xrefs should match up as they are inserted.
Thank you,
Jason Drew
Support Specialist
Product Support
Autodesk, Inc.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
- Highlight
- Email to a Friend
The mechnism that all xrefs must be insert at 0,0,0 is so inconvenient. In the case that there is many same equipments on the same area, it loses the advantage of using multistage xrefs.
For example, if you have 50 same pumps in the pump station, you can only do it by: model the pump, assign nozzles, copy 50 times ,then posittion the 50 copies at the proper location relative to the 0,0,0. Then xrefing it to other master dwgs will have no connection problem. You cannot accomplish it like: model a pump, assign nozzles, xref it to master drawing, copy the xref 50 times, position the 50 copies at the proper location. If xref this file to upstage drawing, P3D will not recognise the nozzle.
The fomer: If changes are make to the pump, copies cannot changes. You must recopy/rearray it.
The latter: Changes can flow to the master drawing. But nozzles lost.
WE NEED XREF MOVE FREELY !!!
- Highlight
- Email to a Friend
I completely understand this, but you have to remember, when you run an Iso, what does the end connection say? If you have 50 lines and then 50 pumps, and they all say the same Pump connection at the end, what do you do?
And how do you count the 50 pumps if they are all named the same? Its one instance of a pump, but how do you represent it in a database? Give it unique PnPID's? Then you might as well make different pumps.
It has to be remembered there is a database backend and it needs to be satisfied in how it makes the data work with the software.
As for keeping it at 0,0, thats logical. You nominate a datum point on a site, and with each equipment model and piping, structural models, you move them in their own respective models, rather than moving the XREF to suit.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Autodesk, Inc.
- Highlight
- Email to a Friend
No, we really need to be able to move the xrefs.
Typically, people want to have one drawing file per piece of equipment as it's easier to model and organize. Then they will usually create an overall general arrangment of the equipment that references each of the equipment drawings. The easiest way to locate the equipment in the general arrangement would be to move the xref, otherwise, we have to open each equipment model, attach the correct references and then move the equipment. I aggree that piping and steel should all be at 0,0, but equipment is a different situation and the program needs to handle locating information in a moved xref.
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
- Highlight
- Email to a Friend
Typically the equipment (and piping and structural) models are broken down into areas, relative to the datum point of the project/plant. From that 0,0 you place the equipment in its place, and then route the piping to that piece of equipment/nozzle/connection point. You make an area of equipment models, then move them individually inside that model to the correct location. You can do one model per equipment obviously, but I don't see any benefit to that, its just more work.
You wouldn't do the same with structural piping rack models, doing them at 0,0 them moving the XREF (and rotating maybe) to the correct point. Its all relative to the Plant datum, wherever that may be (the corner of a building, a fence post, the corner of a pipe rack etc)
A lot of this comes down to the size of the site, how many people working on it, how many area's inside the plant etc etc, but moving the XREF isn't the answer. Keep the models to a 0,0 of the site/project, and then move the elements inside each model, not the XREF's. I have never seen a project that has equipment models moved via the XREF, all equipment is moved inside its model to the correct location. When you do a report on equipment and where the datum point is, they show where the location is to 0,0 and not where the XREF is located, otherwise you would have all equipment placed at 0,0 which is useless for reporting.
Tomislav Golubovic
Autodesk, Inc.
- Highlight
- Email to a Friend
Dave,
Yes, we need to remove this restriction. It's on our enhancement list for the future.
There was some relaxation of this restriction in 2012, I think, but it still holds for xrefs that have connected piping.
Peter Quinn
Senior Product Manager
Autodesk, Inc.
- Highlight
- Email to a Friend
I now have version 2013 and this is still NOT fixed. I have read the autodesk comments that all the equipment should be in one drawing and not each piece in its own drawing. The bad part of this is there can be only ONE guy working on the equipment drawing because it gets locked when open. Having separate drawings for equipment and then xrefed together means many people can be working on the equipment at the same time. We normaly start with simple equipment models, do a general layout and then add detail to equipment ie nozzles at a later time. We don't have a gigantic plant broken down into areas so many can work on it at once. We have a small plant, one area and need many works accessing parts of it at the same time.
