AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Adding Custom "Piing and Equipment" class
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Anyone help direct me in adding a custom field in the <equipment> class settings?
inside <Plant 3D Class Definitions> inside <Piping and Equipment>
I wanted to add a few catagories for Aquaculture and the specific equipment that I use,
so I can have specific fields show up in the equipment reports.
"Do or do not... there is no try"
Master Yoda.
Re: Adding Custom "Piing and Equipment" class
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Select the Equipment class and at the far right you should see an Add button. You can pick your property type in the following dialog. If you choose selection list, you can create a new selection list in the next dialog.
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That is just adding a <property>
I want to add <JLH Equipment> along side <filter> <furnace> <Global Equipment> etc
I use <Filter> < Tank> <Pump> and mostly <Misc Equipment> - but they are quite broad I want to add my own equipment catagory and for the specialized equipment then add my own properties.
John.
Master Yoda.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There's no UI for this. Probably you can try editing the database to add a new class, but i'm not sure what is the repercussion.
Check out my blog http://lazcad.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Although there is no UI to add new classes, it is really quite straightforward to add a new class directly to the database.
I have already documented the procedure here: http://www.cadlinecommunity.co.uk/WhitePapers/Whit
Please feel free to download a ccopy.
Andy
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks! I will go over this.
Master Yoda.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This proceedure works, but it is for SQL Lite. What about SQL Express?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Andy,
As asked on the post below, what about the procedure for a project running on SQL Server ?
I tried to adapt your procedure but with no success.
Thank you in advance,
Alexandre Devos
