AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
AUTO Flange
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So for my current project my AUTO Flange isn't working. I checked the default project(which I made no changes to) and it works. I checked my compund joints and its setup correctly idecitcal to the default project. For the simple joints the only thing I had to change was allowing 125lb flanges to connect to 150. Would that be the reason why It wont auto flange?
I am also using a custom spec, which has flanges, gaskets and bolts, because I can place them in seperatly and they will connect.
SOLVED see next post, new question there!
Re: AUTO Flange
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I solved my own problem, it was the fact that the valve was a 125lb with a 150 lb flange, I have over come this by removing the requirement for a pressure class at the moment. Although i find it weird that the Compund joint was not grabing the information from the simple joint that allows me to add a 150lb flange to a 125 valve.
NEW question, while im routing pipe and i hit "f" for fitting and I add an elbow, then I want to add a flange to that elbow, it auto throws a 1" long peice of pipe inbetween the elbow and the flange, and I dont want it, how can I make that stop?
SOLVED my gosh i jst need to look harder lol, now im just talking to myself. Just below is the Pipe segments where it says 1".
