• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Contributor
    A Question About the Format of Flange Description In Iso.
    67 Views, 0 Replies
    06-14-2012 11:47 PM
    Hi!
    Normally,the description of flange in the iso is"F3 B4 G5",but sometimes I only want to show"F3".
    In order to achieve that,I opened the file "isoconfig.xml",and modify it as below:
    <GroupScheme Name="FlangeGroup" AnnotationStyle="SRectangle" Enabled="true" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Components="Flange Bolt Gasket" Field="PartNumber" IncludeMate="true" MateComponent="Flange" MateTag="XX" MateAnnoStyle="Rectangle" MultipleBlocks="false">
                <Formats>
                  <Format Component="Flange" Format="F{0}" />
                  <Format Component="Bolt" Format="B{0}" />
                  <Format Component="Gasket" Format="G{0}" />
                </Formats>
    <GroupScheme Name="FlangeGroup" AnnotationStyle="SRectangle" Enabled="true" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Components="Flange" Field="PartNumber" IncludeMate="true" MateComponent="Flange" MateTag="XX" MateAnnoStyle="Rectangle" MultipleBlocks="false">
                <Formats>
                </Formats>
    I modified the red part to the blue,but that didn't work.Even I deleted the pink part,I could't achieve that.
    So,the problem is that how can I make the format of the flange description  in the iso "Flange" instead of "Flange Bolt Gasket".
    Thanks!
    Been
    Please use plain text.
