• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Member
    samsonthomas7606
    3R ELBOW CREATION IN SPEC AND ISOMETRIC REPRESENATIONS
    257 Views, 2 Replies
    11-21-2012 04:48 PM
    Hello
    I used PLANTPARTCONVERT to creat new fitting 3R 45 ELBOW and added it to our spec. When i have generated the ISOMETRIC angle shown is 43. See attached pics. Is there anything that I am doing wrong?
    Using Plant3d 2012
    Thanks for any help or pointers
    Samson Thomas
    Please use plain text.
    Product Support
    Re: 3R ELBOW CREATION IN SPEC AND ISOMETRIC REPRESENATIONS
    11-23-2012 03:35 AM in reply to: samsonthomas7606
    Do you have cutback elbows enabled?
    If you select the elbow and open the Properties Palette you can check under "Part Geometry" to see if a cutback angle has been applied to the elbow.
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
    Active Member
    samsonthomas7606
    11-30-2012 09:55 AM in reply to: DanScales
    Hello Dan,
    Thanks for the reply. I tried with cutback elbows disabled. I still did not work properly. I created a brand new project and this new spec worked just fine.
    Thanks for your reply.
    Samson
