AutoCAD Plant 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
3D Piping and PID workspaces gone
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hello!
I lost my 3D piping and PID workspaces. I always have to type "menu" command and load pnp.cuix when I run P3D.
Is there a way to set this right permanently?
Thanks in advance!
Attila Vallyon
Re: 3D Piping and PID workspaces gone
- Highlight
- Email to a Friend
It should be set as your main cui unless you are running a customized setup.
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
- Highlight
- Email to a Friend
I am sorry I did not thank you your reply.
The main cui file is what you attached, but it still does not work.
And I have Plant design suite 2013 premium.
Attila Vallyon
- Highlight
- Email to a Friend
Can you post a screenshot of your options (the same section that the image I posted shows - main customization file)?
Isaiah 57:15
ECAD, Inc.
- Highlight
- Email to a Friend
Here you are.
Now I have a much bigger problem.
The acad.cuix autoload on opening every new drawing.
How can I edit this autoload thing. Because I can not work with the software this way anymore.
It is nonsense that I have to input the menu command and select the pnp.cuix after every drawing opens.
Attila Vallyon
- Highlight
- Email to a Friend
Well, I uninstalled the plant design suite and installed the Plant 3D alone instead.
I have no this kind of problem now.
Maybe an old acad.lsp caused the problem.
I checked the loaded applications and there was and old acad.lsp
Now I have only acad2013.lsp.
I am testing now.
Attila Vallyon
- Highlight
- Email to a Friend
You probably could have done a repair/re-install of Plant back to its basic installation.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Autodesk, Inc.
