When setting up a new joint type (for lined pipe), In the required/optional matches I want to include 'Pressure Class' and 'Facing'.
Just like in the ones ootb.
When you go to the select class property dialogue box, there is no option to add them.
Solved by TomislavGolubovic. Go to Solution.
It's true, there isn't. To add in wish list of Plant3D 2013.
Edit DefaultConnectorsConfig.xml in the project folder.
