When setting up a new joint type (for lined pipe), In the required/optional matches I want to include 'Pressure Class' and 'Facing'.
Just like in the ones ootb.
When you go to the select class property dialogue box, there is no option to add them.
Solved by TomislavGolubovic. Go to Solution.
Edit DefaultConnectorsConfig.xml in the project folder.
