AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
valves not fitting with flanges
2 REPLIES 2
JRPalmer
347 Views, 2 Replies
I seem to be unable to connect a flange to a flanged ball valve and vice versa. I can create the flange by adding pipe after the ball valve. The port connections are both raised flanges with the same nominal diameter. There a message that says don't fit. I have also tried to use connect componet to adjacent and it says something about connection ports not being the same.
2 REPLIES 2
PeterQuinn
in reply to: JRPalmer
Any more info? Does this happen with any spec? Any project?
Peter Quinn
Senior Product Manager
Autodesk, Inc.
JRPalmer
in reply to: PeterQuinn
I can not connect a flange to a flange valve (without bolts and a gasket). The only way around that was to start the pipe from the flanged valve and let Autoflange take care of the rest. But when I want to connect 2 flanged objects together it does not work even if they have the same end, facing, and nominal diameter.
Do I need to create a new joint type? Or create an autogasket(kinda like autoflange)?
And this happens with my custom specs and possibly with the regular specs.
”Boost
