Solved by Artur.Kosakowski. Go to Solution.
I'm not sure if I understand you correctly. If you want to run Robot from 'inside' of Plant 3D then that is not possible. On the other hand you can model the support either as solid, shell or bar type model inside Robot and analyze it.
You may want to use Robot forum for further questions about this program
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/bd-p/351
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Thank you very much - You did answer my question. You can't use the supports built into P3D in Robot - that's what I wanted to know!!!
