Is it possible to define or control the numbering of the welded connections of a pipe and to overwrite the automatic numbering of the isogen-file with those customized numbers?
Weld Numbering Systems
Weld Numbering can be done in different ways :-
*Per Drawing or Per Pipeline
*One Weld Number Sequence for all types of Weld - or a separate Weld Numbering
Sequence for each ( Fabrication, Erection and Offshore )
User Dictated Starting Weld Numbers
This feature permits different type of Welds to be numbered within
their own ranges - e.g.
Fabrication Welds 1 - 99 ( Start at 1 )
Erection Welds 100-199 ( Start at 100 )
Offshore Welds 200-299 ( Start at 200 )
This is done with a -97 record in the options file.
Best of luck ..!
vijay
9900098018
