Can anyone advise solution for text problems on my Iso drgs - see attached.
Gary
Solved by TomislavGolubovic. Go to Solution.
just on the NB issue, you haven't edited the final.alt file at all?
Reloaded prog for good measure.
Found & Solved issued - error on piplinesettings file (must have been there for a while) & reset the OPL 41 switch to correct setting. Had run off a number of isos with original settings, but the only time the wrong size was being reported was on the half pipe sizes
Regards
Gary
Hello!
I have some questions:
Where did you set up the connected elements showed in dashed line?
Where did you change the symbol of the pipe support?
Thanks in advance!
