AutoCAD Plant 3D Forum
tag in the PID
3 REPLIES 3
M-BRF
446 Views, 3 Replies
tag in the PID
good morning
I have to put the tag in the PID but these are very long because they have a lot of data or fields that I can hcer tag line is divided into two lines and the data manager tag contains these two lines?
I tried to divide them into two lines but just get the tag that is in the data manager contains only one of the two lines
a greeting
Regards and thanks
I do not understand a lot of Inglés and I Helped With The google translator, perdor for errors
3 REPLIES 3
Dan.Scales
in reply to: M-BRF
Unfortunately it is not possible for the tag annotation to be created on two individual lines.
Dan
Dan Scales
M-BRF
in reply to: Dan.Scales
Too bad VERSATILITY IN THIS ITEM NOT AS IF YOU HAVE OTHER POINT PROGRAM.
THANKS FOR YOUR HELP
M-BRF
DanScales.. tanks
best regards
joaquin
”Boost
