good morning
I have to put the tag in the PID but these are very long because they have a lot of data or fields that I can hcer tag line is divided into two lines and the data manager tag contains these two lines?
I tried to divide them into two lines but just get the tag that is in the data manager contains only one of the two lines
a greeting
Regards and thanks
I do not understand a lot of Inglés and I Helped With The google translator, perdor for errors
Solved by Dan.Scales. Go to Solution.
Unfortunately it is not possible for the tag annotation to be created on two individual lines.
Dan
Too bad VERSATILITY IN THIS ITEM NOT AS IF YOU HAVE OTHER POINT PROGRAM.
THANKS FOR YOUR HELP
