AutoCAD Plant 3D Forum
sqlite PnPCompletionStatus error message
5 REPLIES 5
1351 Views, 5 Replies
I know nothing about SQLite. I've been getting the error message below ever since I got Plant 3D 2012. I'm running 2013 64bit now and I'm still getting the same message. Can't recall who told me not to worry about it. I'd like to know what 's causing it and what I should do about it.
PnPCompletionStatus.FailedToAcceptChanged
SQLite
no such table: PnPBase
5 REPLIES 5
dave.wolfe
Can you post your .dcf files for a project?  I didn't think the program could function without a pnpbase table.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
stevenhultgren
in reply to: dave.wolfe
I'm having a similar problem with Plant 3D 2013. My error message says this: PnPCompletionStatus.ColumnAlreadyExistsInDerivedClass [(column_name={Spec}),(table_name={InLineAssets})] (Note I had to replace greater than and less than symbols with curly brackets for this post.) Can you help me figure out what's wrong?
Never mind. I solved my own problem. There was something wrong with my 3D model template. I replaced the my custom one with the default one.
what was wrong with your template? mine is doing this as well. I'm currently using Plant 3D 2016. The client supplied their templates & this error is driving me insane...
dave.wolfe
in reply to: Isham_Dean21
I've now noticed that this error tends to appear when you mix templates from different project parts. For example, using a PnID template in orthos, or models.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
”Boost
