Hello
in P3D 2012 I loaded pointclouds, set virtual style realistic and had colored clouds and the performance (zoom in/out) was OK
in P3D 2013 I see no colors and the performance is very bad, and there is always a bounding box for each pointcloud.
Where are the colors?
Can I improve the performance? (but not with the point density)
Can I hide the box?
Guido
Solved by GSC_HAYA. Go to Solution.
Solved by kubitTilo. Go to Solution.
You should enable hardware accelerated graphics (using _3DCONFIG command, "Manual tune" button).
