Goog morning
I can create equipment with plantequipmentcreate and I can add nozzles.
Sometimes when I select an created equipment there is a pencil-grip so that I can edit the nozzle, but sometimes it is not?!
Which depends that on?
G
Solved by PeterQuinn. Go to Solution.
What version of Plant 3D are you using?
Also, do you have a certified graphics card and driver?
Find Recommended Hardware here
Dan
Use the Ctrl key to select the nozzle and get the pencil icon.
