hello
is it possible to had 20% on subtotale for part
for exemple when the report say you have 10 elbow 90°.. i need in an other columns it say 12 elbow 90°...
because the report is the exact numbur of part but when we ship material we need more parts...
i don't know if it's clear..
thank you
Yes, you could do it using scripts. Look at the default 3d parts BOM and open the scripts section. There is a function they use to get the total that will be used. You can replace the two function below (feetInchesFromObject and tableCell4_SummaryCalculated) with the code below.
I've modified the function to return 120% of the items, and made it so any fractional value round up to 1", this part just affects the piping.
// Return the specified object as a double value formatted
// into feet and inches.
private string
feetInchesFromObject(object obj)
UsedFeetandInches = true;
System.Diagnostics.Debug.Assert(
obj != null,
/*NOXLATE*/"feetInchesFromObject: obj parameter is null");
if (obj == null)
return string.Empty;
double value = System.Convert.ToDouble(obj);
//add fudge factor to the double
value = 1.2 * value;
// Round the initial value to three decimal places
// to avoid borderline rounding cases than would
// have resulted in very small or very large fractional
// inches.
double inchesFull = System.Math.Round(value % 12, 3);
double inchesOnly = System.Math.Truncate(inchesFull);
//round up the inches if there are any fractional left overs from our fudge factor
if(inchesFull - inchesOnly > 0)
inchesOnly++;
// Compute the fractional inches, if any.
string fracText = string.Empty;
double frac = inchesFull - inchesOnly;
//make sure there are no fractional values
frac =0;
if (frac > 0.0) {
fracText = string.Format(
/*NOXLATE*/" 1/{0}",
System.Math.Round(1 / frac)
// We always include the feet and inches.
// The fractional inches are optional.
return string.Format(
/*NOXLATE*/"{0}'-{1}{2}\"",
System.Math.Truncate(value / 12),
System.Convert.ToString(inchesOnly),
fracText
private void
tableCell4_SummaryCalculated(
object sender,
DevExpress.XtraReports.UI.TextFormatEventArgs e)
UsedFeetandInches = false;
textFeetInchesIfColumnImperial(/*NOXLATE*/"MeasureUnit", e);
//don't do anything if we already calculated the feet and inches
if(UsedFeetandInches)
return;
//get the value
double sum = System.Convert.ToDouble(e.Text);
//add our fudge factor, and round up to the nearest integer ie 2.1 goes up to 3;
e.Text = Math.Ceiling(sum * 1.2).ToString();
bool UsedFeetandInches;
hello
thank's for your answer
i copy paste the script but it say erraor on line 57 any idea ?
Try substituting this in the summary calculated section
where it says:
//get the value
use this:
//get the value
double sum = 0.0;
try{
sum = System.Convert.ToDouble(e.Text);//add our fudge factor, and round up to the nearest integer ie 2.1 goes up to 3;
catch{
//do nothing if we couldn't convert to a double
