when I hold the Ctrl key and click the nozzle.(ctrl+click ) ,the edit box did not show.
The commnad line show :
_.PlantNozzleEdit
_.PlantPipeAdd
why run the "_.PlantPipeAdd" command?
on which type of equipment?
Place another piece of equipment to see if it happens, otherwise create a new project and see if it does it in that also.
Pressing CTRL and the nozzle should bring up the pencil icon for the nozzle, then you press the Delete key, and it gets deleted.
create a new project ,but the result is same.
you try it :
input commnad :op
then click the reset on the Profiles tab.
you cad find the result.--can't delete nozzle!
