AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
pipe, flange and valve problem
3 REPLIES 3
elenapeng
1380 Views, 3 Replies
Pipe, Flange and Valve Problem
I have tried to model pipe, flange and valve together and they cannot be connected. Please see below list for the spec editor:
PIPE, SDR11 PE100 SERIES1 VINIDEX AS/NZS 4130   END CONNECTION: PPL
BACKING RING, TABLE D VINIDEX                               END CONNECTION: FL, LAP
FLANGE STUB, SDR11, VINIDEX                                  END CONNECTION: LAP, PPL
BOLTSET, LB, STUD BOLT                                           END CONNECTION: FL
GASKET,TABLE D, AS 2129                                         END CONNECTION: FL
BALL VALVE  FROM CUSTOM PART                           END CONNECTION: FL
Pipe and flange can be connected, but I cannot put any more flange or valve on.
Can anybody please tell me what is wrong? Much appreciated.
Thank you!
Elena
3 REPLIES 3
rajsekarpillai
in reply to: elenapeng
Try these end connections...
BACKING RING, TABLE D VINIDEX                              END CONNECTION: FL, (add FF or RTJ for facing), LAP
FLANGE STUB, SDR11, VINIDEX                                 END CONNECTION: LAP, (add FF or RTJ for facing), PPL
BOLTSET, LB, STUD BOLT                                           END CONNECTION: (remove the endtype)
GASKET,TABLE D, AS 2129                                        END CONNECTION: set "Undefined_ET", add FF or RTJ for facing
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Plant Solutions - AEC
Tags (1)
elenapeng
in reply to: rajsekarpillai
Thanks for your reply.
I used end connections...
PIPE, SDR11 PE100 SERIES1 VINIDEX AS/NZS 4130         END CONNECTION: PL
BACKING RING, TABLE D VINIDEX                                    END CONNECTION: FL, ( FF for facing), LAP
FLANGE STUB, SDR11, VINIDEX                                       END CONNECTION: LAP, ( FF for facing),   BV        BOLTSET, LB, STUD BOLT                                                END CONNECTION:   None        GASKET,TABLE D, AS 2129                                             END CONNECTION: set "Undefined_ET",  FF for facing
GATE VALVE, PN16, PFS, PFS, METAL SEATED, TYCO WATER                           END CONNECTION: FL
These working very well. But I cann't put valve on it and ISO was not connect. Please see attached.
Thank you,
Elena
rajsekarpillai
Good to know that the end connection mappings are working!
Can you try placing the component one by one such as Pipe -> place the LAP Flange on the pipe end ->Place the Valve on the Flange End ->  then Place the Flange on the Valve end -> pipe ...?
Meanwhile, I will try it in my end to find out the problem.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
”Boost
