AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
order linenumber size spec on iso annotation.
2 REPLIES 2
424 Views, 2 Replies
I mannaged to get the "service" in my linenumber annotation
<LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{0}-{1}" Alignment="SkewAligned" LeaderStyle="AsNeeded" ComponentFields="Size PIPING-SPEC" LineFields="PIPELINE-REFERENCE ATTRIBUTE1" ComponentFormat="{1}-{0}" LineFormat="{0}-{1}" />
so i get linenumber service spec size
i realy want size service linenumber spec on my iso (as on the P&ID and ortho)
i tried switching around the {0} and {1} arround but can not get it right....
thanks
Lucas
2 REPLIES 2
not sure if this is what you're after.
You can change the annotation setup in:
Project setup - p3d DWG setup - p3d class definition - piperun component
in the block you can edit the order of the callout.
See picture.
//Mikael
Hi Mikael,
No, this is already done for the ortho drawings
i mean the text on the isometric drwing, generated when creating an iso...
”Boost
