using 2011 P3D. Have a contorted piece of a tank with a few 3D solids attached to a "tank" using "attach equipment." I have some nozzles coming out of the 3D attached solids at weird angles.
I draw a line where I want the nozzles to go. I select the equipment. everything shows it is selected, original tank and attached 3d solids, select the nozzle number. go to location, chose line option, select a line that runs into (and I did this with the line running thru it as well) to tell P3D where I want the nozzle........
here is the error I am getting, "The line does not intersect with the equipment! Please select another line!"
did this on all the "attached 3D model parts to the equipment" none worked.
did this to a line that is touching the "original" tank and it works.
For some reason attaching a nozzle to a line with the line going thru (or coming out of) a 3D attached part does not work, err, at least for me. not one time.
It does work if the line is going thru or coming out of a regular part. It works everytime.
is this a bug or just me?
same thing here. I create a Tank with 'PLANTEQUIPMENTCREATE', then 'PlantNozzleAdd' using Nozzle Location: Radial and Top and all OK. Then using the Nozzle Location: Line, for a drain nozzle that I 'PlantEquipmentAttach' when 'Select Line' I end up with 'The line selected doesn't intersect the equipment! Please select another line! see photo
Any solution ?
thanks
AP3D 2013 SP1
