AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
need to convert a iges file (valve) into a "useable" valve on ttemplate
4 REPLIES 4
chrishope12
414 Views, 4 Replies
I have imported a iges file into my project in AutoCAD Plant 3D, but if I convert it to a piece of equipment or a block then it slows down the drawing REALLY BAD! I would take time and draw each valve I have, which are manual and acuated valves ranging in different sizes from 1" up to 4".
I have not used the spec editor much and really get lost in creating my own valves at this point. I already have these 11 or 12 valves in the drawing but are they are not solid objects and they are not compatiable with my piping.
Can someone help me with the steps I need to take in converting what I have into workable piping componets...Please
4 REPLIES 4
Have a look at the youtube channel in regards to editing catalogs and specs. There is also a video that shows how to make custom parts.
I would personally put all these items into your own spec to use for future projects, rather than doing them one at a time when required.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
JohnHolder
in reply to: chrishope12
Inventor Fusion can convert to DWG fairly easily, then when the model looks proper and in the correct format, block it and convert it.
I have a bunch of former IGES files - butterfly valves, that I have converted this way and it works fine.
John.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
chrishope12
in reply to: JohnHolder
Thank you for the info. Now, I have created the dwg. file from the iges. through Inventor Fusion, which was really nice, but I now need to know how to make this dwg. valve work in spec editor.
Do I make it a block? which if I do, then I can't snap flanges or pipe to it. What do I do to make this valve a useable valve or place it on a template?
JohnHolder
you create a block of your valve. Then use the command  <plantpartconvert> this will let you add your ports  Once you have this done, then it's into the spec editor.
open your spec and catalog
add it to your catalog and spec.
Master Yoda.
”Boost
