Hi
I encounter the problem to how create line list report if I am not using PID plant 3D. at the project Setup I see for create line list I should used PID. is that away to create line list from 3D model?
Thanks in advance for your advise.
Regards, Saman
You can use Plant Report Creator (PnPReportCreator) to do this. It's found in your installation directory.
Here is a link as well for a help document for Report Creator. This will help with some of the questions you might have in using Report Creator.
http://docs.autodesk.com/PLNT3D/2014/ENU/report_designer.pdf
Quentin Contreras
Technical Support Specialist
