AutoCAD Plant 3D Forum
isometric BOM in Excel
1 REPLY 1
Peter_Jansoone
725 Views, 1 Reply
BOM, weld list etc can be exported to Excel when creating ISO's. But on some machines the split into columns isn't correct. It seems to split on spces in the text in stead os semi-columns. Anyone an idea ?
fe: this comes into one cell
ID;"QTY";"ND";"SCH/CLASS";"DESCRIPTION";
While the space in PIPE SEAMLESS makes the text split
1;"5.2M";"80";"40";"PIPE
 SEAMLESS
I checked regional settings/list separator, but that isn't the cause.
Peter Jansoone
Plant Design software consultant at Arkance Systems Belgium
1 REPLY 1
tomaz.rode
in reply to: Peter_Jansoone
Hi Peter,
I had such a problem on P3D 2014. Now I tried with P3D 2019 and nothing has changed regarding this issue.
Could somebody from Auodesk tell us what is the problem? So as works, this function is not usable. I need to export to CSV and import in Excel for every sheet - a lot of unnecessary work.
BRG Tomaz
”Boost
