AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
how to get a pipe elevation once it is drawn
5 REPLIES 5
syria89
5093 Views, 5 Replies
i have no idea how to get an elevation of a pipe once it is drawn
i already tried to selecte it go into its properties and try to see if there is an elevation data but there is none
so need help guys
thanks
5 REPLIES 5
TomislavGolubovic
in reply to: syria89
Pick the pipe and there is a grip that looks like a triangle (it'll be above the pipe, not under/beside it) and this, when picked, will let you change the elevation (TOP, COP and BOP). From there you can see what the EL is at.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
syria89
in reply to: TomislavGolubovic
i tried what u asked
but the trinagle which is above is to change part
the triangle which is below it is to change elevation but it will start from 0 then you add how much u wanna bring up or down
but the only way i found as i show it in the pic attached it is to click on the middle blue square and see what is the coordinate in the buttom left of autocad window
btw i am using autocad plant 3d 2013
ElrinaM
Hi there
I know this reply is 3 years overdue, but at least now a solution is shown.
Switch on Dynamic Input (F12)
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Kudos are greatly appreciated. Everyone likes a thumbs up!
CADPRO Systems
www.cadpro.co.nz
in reply to: ElrinaM
That's right, but if it still does not appear set the Drafting settings menu (CTRl+shift+p), tab Dynamic input, Enable dimension input where possible marker to ON. it should be working OK now, when you select a pipe.
dave.wolfe
Note that this was originally posted in 2012. In plant 3d 2014 extension 2 they added bop, cop to the properties list so they display correctly now.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
”Boost
