AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
how do you control the size of this box?
3 REPLIES 3
mrc9961
567 Views, 3 Replies
I can't find the variable that controls this...
thanks
3 REPLIES 3
Arun_Kumar_K
in reply to: mrc9961
Edit the size in isometric symbol under project properties
JarrodMudford
See attached image. Change the Annotation text scale.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Jarrod Mudford
Plant Solutions Consultant
Global Services
cyklosarin
in reply to: JarrodMudford
This one is not variable by changing annotation text scale. Enclosure type annotations (circle, rectangle etc.) you can only change by changing size in block (isometric symbols under ISO DWG settings as THERMAX-CHENNAI wrote). The only think you can change by annotation text scale is text in a brackets or without enclosure. I fought very long with this one.
Regards
Dominik
”Boost
