AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
diagonal lines in ortho views
2 REPLIES 2
hardell
592 Views, 2 Replies
Is it possible to get rid of the diagonal lines in ortho views?
I make walls in ASD and xref to a plant 3d modell, and make ortho views. Everything works fine except for the diagonal lines.
Best regards
2 REPLIES 2
batone79
in reply to: hardell
edit block..
erase lines..
done!
hardell
in reply to: batone79
Thanks for the suggestion,
the blocks are anonymous and are not possible to edit. you can of course exlode them and remove the lines, which i did. this is solution is not very convinient if you have many drawings. every time you make an update, the lines are there again. there must be a better way to get rid of the lines.
//J
”Boost
