help me!
As everyone knows a project pipeline without instruments is rare in almost all lines have instruments such as on off valves, control valves, flow transmitters, pressure transmitters ............. so help me how do I insert instruments like the attached file.
Halo...
Did You try to create custom element , and make like inline instrument, because You need correct ISO information...
I think that Procedure for Plant3D 2011 is ...
> Model a 3D element with appropriate dimension, in model that You wish to have element
> Create block
> Use plantpartconvert command on command line (add connection ports)
> Then use custom part option in Plant 3D
I hope that I help a little bit ....
