Hi Autodesk Support Team,
how Can I copy items from Catalog to another Catalog, and same Issue for Specs
I tried May Time Copy from Catalog and Pest but not Appered like there no action
Please Help
Ahmed Helal
Solved by dave.wolfe. Go to Solution.
http://www.pdoteam.com/2012/02/copying-between-catalogs-for-autocad-plant-3d/
You can do a similar thing for specs while on the spec tab.
Thanks Dave,
These Steps I was made but i discovered my problem, I was open two Spec Edit 2 Times and i was try to copy from one to the other one witches wrong i have to
open only one Spec editor.
anyhow thanks Again
Ahmed Helal
Hi Ahmed,
Currently the solution which Dave has sent is only possible for catalogs, not for specs. I have created here a case for our development department.
Best regards
Bernd
Yes you can copy from one spec to another in the same Spec editor session.
http://www.screencast.com/t/Hb46BnEo0
Hi Dave,
I did run into an error when I tried the same steps. Thoug about it as an issue. Now I have tested it again on a different machine and there it works as it should work.
Thank you for pointing this out.
Bernd
Please mark my post as the answer if it answers your question. Marking answers helps other find solutions faster. Thanks!
