AutoCAD Plant 3D Forum
change/customize the project folder structure?
7 REPLIES 7
Message 1 of 8
1446 Views, 7 Replies
Is there a way of customizing or changing the project folder structure.
I have attached a screenshot of the standard P3D folder strucutre and one of our companies standard folder structure.
Is it possible to modify it or change it in any way?
7 REPLIES 7
Message 2 of 8
cadwomen
it is possibel, but dont do it !
dot () and ~ are to bad
cu cw
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Message 3 of 8
in reply to: cadwomen
Why are you saying not to do it?
Message 4 of 8
cadwomen
half the truth
Wikipedia
cw
Message 5 of 8
the link is just explaining what a filename is. i dont see the relevance?
Message 6 of 8
cadwomen
it is hart to explain for me
"When they allow any Unicode character, some file system utilities and naming conventions prohibit some particular characters from appearing in filenames"
" Windows, the filenames "." and ".." have special meanings (current and parent directory respectively"
and it will make toubel , belive it or not  or mayby someone are able to expain it better .
cw
Luchtime Smiley Happy
Message 7 of 8
dave.wolfe
For Folder names and file names, best practice is to avoid special characters.  While Windows may allow it, not all programs and/or parts of Windows can handle special charactors in the file names.  For example, one client had issues with his project manager, because his project started with #. When he would open drawings, it would say the drawing is not in the project.
So...stick to dashes and/or underscores for the best results.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 8 of 8
dgorsman
in reply to: dave.wolfe
Full stops "." usually work, except for some older programs which only expect them to delineate file extensions.  But otherwise, I agree on the special characters.  Wildcard searches usually stumble over these characters.  Not sure about REGEX based comparisons, though, which may explain why they work with some programs and not others.
”Boost
