AutoCAD Plant 3D Forum
bill of materials
3 REPLIES 3
TBoo
605 Views, 3 Replies
bill of materials
I am currently working in Autodesk Plant Design Suite Premium 2012 and im reading up on some solved bill of material issues. they are all saying to go to the report creator and pick the plant 3d BOM. that is where my problem comes in to play. My report creator does not have this option. is this something i need to create or is there a service pack that adds this or maybe some hot fix or something i didnt do correctly in the install? Please help.
3 REPLIES 3
KenFauver
in reply to: TBoo
select 3D Parts from the report list
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
dpappan
in reply to: TBoo
Is there a way to quickly generate a simple BOM excel file from the command line? The report designer is very difficult to use. Is there a third party software and plugin that allows us to do this?
See attached for example of what we need... it's very basic.
Thanks!
TomislavGolubovic
in reply to: dpappan
@dpappan, have you used the Data Manager from the ribbon inside Plant3D? That will export a list in Excel for you
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
”Boost
