Hello i have a very big problem i made my3d with pvc spec evrithing is ok
when i generate iso there is unconected line....
the header is good ( toto.png) and the branch not you can see turlututu pict....
evry pvc iso are the same i try with different catalog and spec but it's the same
the problem is the GL code ( glue join)
on steel spec evrything is ok....
i think the problem is in the isoconfig.xml i try dirrent things but no result...
the pcf are not good also i chek...
thank's
