AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
autocad plant 3d 2014 extension 1
2 REPLIES 2
JohnHolder
364 Views, 2 Replies
The BOM is a good step in the right direction.
But why exclude <equipment>?
I go into <table setup> then <add column>  Select Class Property.
I try highlighting <Equipment> and <Long Description (size)> OR
<Misc Equipment> and <Long Description (size)>
and all it does is double the description for the pipe and fittings.
is there something I'm doing wrong?  or was this just left out?
John.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
2 REPLIES 2
Hi John,
This is currently not possible. Equipments will be excluded for isometric drawings. I have created an enhancement request for you.
Regards
Bernd
Bernd G.
Senior Product Support Specialist
JohnHolder
in reply to: JohnHolder
Sorry i should have said Orthographic drawings. I cannot use isometrics already since ISOs cannot deal with flush bushings.
John
Master Yoda.
”Boost
