AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
assembly
6 REPLIES 6
patpat78
400 Views, 6 Replies
assembly
hello is it possible to creat standart assembly i mean for exemple standart by-pass just put it on the pipe with fixed dimension
or for pressure indicator ...
when we put a pressur indicator on the pvc pipe we use 4 or 5 parts befor the indicator it's not easy and quick to do
any idea i know that pdms do that so i hope p3d can..
thank's
6 REPLIES 6
Ahmed1081975
in reply to: patpat78
Make As Block and after you placed Exploading
Ahmed Helal
patpat78
in reply to: Ahmed1081975
i try that whay but when the block was generated evry part are disconect... any other idea
Ahmed1081975
I'm sorry this what i know and working with me I agree with you
Sometimes disconnected all the parts after exploded
 Let’s wait Autodesk support.
Ahmed Helal
patpat78
thank's for your answer
for me all part are disconect when i apply the bloc generation not if i exploded it
Dan.Scales
The disconnect should only appear in the block that you create. If you insert the block and explode it it should stay connected.
Dan
Dan Scales
patpat78
in reply to: Dan.Scales
done thank's all
i steped at the block creation because of disconnected parts ... but it works as you said 😉
”Boost
