after installing Plant 3D 2013 i migrated my specs and catalogs from 2012. when i opened the specs to do some work on them i got this message...see attached...if i have already migrated the content why am i getting this message?
Make a copy of the spec and extract it to a folder (it's a zip file). Check for an editor folder. Is there a file pointing back to the old catalogs? You should be able to make it point to the new location and rezipped it.
I have the same problem as "jedmxr" has. Dave, I don't understand your answer: The spec-files have the endings .pspc, .pspx, are these really zip-files? How to I extract them? How do I see to what cat-files the spec-files are pointing?
We discuss it a little bit in this post:
http://www.pdoteam.com/2012/02/setting-up-network-catalogs-for-autocad-plant-3d/
If I'm modifying them, I'll make a copy, and change the extension to .zip. Then you can extract it. If you use a program like 7Zip, it will extract the files without you having to modify the extension.
Inside the extracted files, there is an editor folder with contains a file (I think xml). That xml has a path to the referenced catalog.
