AutoCAD Plant 3D Forum
aaarggggg crap content
13 REPLIES 13
Message 1 of 14
732 Views, 13 Replies
2012....still no metric based threaded nozzles in the acat
Tags (2)
13 REPLIES 13
Message 2 of 14
ybogdanov
You can migrate the catalog of Nozzles from 2011... but I don't understand why in 2012 there isn't this kind of nozzles.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Message 3 of 14
rajsekarpillai
I would like to understand your metric content requirement in detailed.
Can you describe the metric threaded flange standards that you are looking for?
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Plant Solutions - AEC
Autodesk, Inc.
Message 4 of 14
in reply to: rajsekarpillai
Equipment often have threaded nozzles
Both male and female
in all types of threads...in Australia mainly BSP (NPT is often used also)
BSP and NPT are usually refered to only using the metric sizes [we call it a 50 not a 2" and not usually 2"(50) or 50(2")]
The nozzle.acat does not have nor does it look like it has capability to add THDM nozzles at all
It appears to have a couple of asme THDF nozzles, but they are inch based not metric (the edit inch cat in metric units is NOT satisfactory) and dont seem to work at all.
At the moment the only way i can get a male metric BSP nozzle is to add a piece of threaded pipe (unassigned) to equipment model...craps out the iso though
Message 5 of 14
rajsekarpillai
Thanks for your prompt reply!
I would like to work with you to address the issue.
I can help you to create the THRD flange in the nozzle catalog.
Please contact me:  s.r.rajasekaran@autodesk.com or plant.content@autodesk.com
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Autodesk, Inc.
Message 6 of 14
dgorsman
DN isn't the only "metric" size in use - metric OD (e.g. 60.3) is also needed, particularly with CSA based standards.
Message 7 of 14
ybogdanov
in reply to: dgorsman
You can create in the nozzle catalog a copy of one of the exist DIN nozzles, and then change the END type to THDF or THDM.
Yury Bogdanov
Barcelona (Spain)
Message 8 of 14
in reply to: ybogdanov
thats a 4".....are you using a metric/imperial project.
I need metric nozzles....for a metric project
That also looks like 2012....need to finish the project in 2011
Message 9 of 14
I actually ran into this as well, but the pull down menu only has THDF, no THDM (P3D 2012)
Message 10 of 14
Here is a screenshot of the pull down of the "End Type" which shows only THDF
Message 11 of 14
PeterQuinn
Thanks for everyone's feedback on this topic. We're working on a content pack to resolve this. I can't give you a date, but I can tell you that a content pack is planned.
Peter Quinn
Senior Product Manager
Autodesk, Inc.
Message 12 of 14
ybogdanov
The THDF connection there isn't in your list because you don't have add any nozzle with this connection. Go to Spec Editor and add nozzle with this connection.
Yury Bogdanov
Barcelona (Spain)
Message 13 of 14
in reply to: PeterQuinn
Thanks Peter,
I have a couple of projects due out soon that have these connections.
It would be great if at least a sample piece of content could be created ASAP and put up on the content area so we can copy and create a couple of our own, with the full content as autodesk sees fit to create coming as an update late.
Cheers
Richard
Message 14 of 14
ahhh...just added one in 2012...Smiley Happy
”Boost
