AutoCAD Plant 3D General
Valued Mentor
Rich.O.3d
Message 1 of 14 (468 Views)
aaarggggg crap content
468 Views, 13 Replies
08-21-2011 10:13 PM
2012....still no metric based threaded nozzles in the acat
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Valued Mentor
ybogdanov
Message 2 of 14 (462 Views)
Re: aaarggggg crap content
08-21-2011 11:51 PM in reply to: Rich.O.3d
You can migrate the catalog of Nozzles from 2011... but I don't understand why in 2012 there isn't this kind of nozzles.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Employee
rajsekarpillai
Message 3 of 14 (418 Views)
08-22-2011 08:59 PM in reply to: Rich.O.3d
I would like to understand your metric content requirement in detailed.
Can you describe the metric threaded flange standards that you are looking for?
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Plant Solutions - AEC
Valued Mentor
Rich.O.3d
Message 4 of 14 (414 Views)
08-22-2011 10:44 PM in reply to: rajsekarpillai
Equipment often have threaded nozzles
Both male and female
in all types of threads...in Australia mainly BSP (NPT is often used also)
BSP and NPT are usually refered to only using the metric sizes [we call it a 50 not a 2" and not usually 2"(50) or 50(2")]
The nozzle.acat does not have nor does it look like it has capability to add THDM nozzles at all
It appears to have a couple of asme THDF nozzles, but they are inch based not metric (the edit inch cat in metric units is NOT satisfactory) and dont seem to work at all.
At the moment the only way i can get a male metric BSP nozzle is to add a piece of threaded pipe (unassigned) to equipment model...craps out the iso though
CAD Management 101:
Employee
rajsekarpillai
Message 5 of 14 (415 Views)
08-22-2011 11:01 PM in reply to: Rich.O.3d
Thanks for your prompt reply!
I would like to work with you to address the issue.
I can help you to create the THRD flange in the nozzle catalog.
Please contact me:  s.r.rajasekaran@autodesk.com or plant.content@autodesk.com
Thanks & Regards,
S. R. Rajasekaran
Product Manager
dgorsman
Message 6 of 14 (392 Views)
08-23-2011 08:52 AM in reply to: rajsekarpillai
DN isn't the only "metric" size in use - metric OD (e.g. 60.3) is also needed, particularly with CSA based standards.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Valued Mentor
ybogdanov
Message 7 of 14 (346 Views)
08-29-2011 08:18 AM in reply to: dgorsman
You can create in the nozzle catalog a copy of one of the exist DIN nozzles, and then change the END type to THDF or THDM.
Yury Bogdanov
Barcelona (Spain)
Valued Mentor
Rich.O.3d
Message 8 of 14 (335 Views)
08-29-2011 02:52 PM in reply to: ybogdanov
thats a 4".....are you using a metric/imperial project.
I need metric nozzles....for a metric project
That also looks like 2012....need to finish the project in 2011
CAD Management 101:
Valued Contributor
pkw167
Message 9 of 14 (303 Views)
09-02-2011 06:22 AM in reply to: ybogdanov
I actually ran into this as well, but the pull down menu only has THDF, no THDM (P3D 2012)
Valued Contributor
pkw167
Message 10 of 14 (296 Views)
09-02-2011 07:43 AM in reply to: pkw167
Here is a screenshot of the pull down of the "End Type" which shows only THDF
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
