AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Wye Tee Iso
2 REPLIES 2
richard.imrie
711 Views, 2 Replies
Wye Tee Iso
Having a bit of bother with a custom symbol for wye tees. I have created the block and all ports align with their respective ports on the iso, however one leg of the tee doesn't seem to strech to meet the port. See below clips of my block configuration and my output iso. Any suggestions?Wyeblock.png
Tags (1)
2 REPLIES 2
Dan.Scales
in reply to: richard.imrie
Could you test with Extension 1 loaded and let me know the result?
If the problem still occurs try using the standard Tee isometric symbol.
Dan
Dan Scales
richard.imrie
in reply to: Dan.Scales
Spoiler
Dan,
I have extension 1 installed on my machine already. The problem you are seeing is iso's produced with the most up-to-date version of Plant.
I have also used the normal tee block to produce the wye symbol with no luck.
Furthermore, i found that a hotfix was released for 2013 to correct wye's on isometrics.Maybe this hasn't been brought forward to 2014?
”Boost
