Hi all,
Sometimes, i put a flow direction on my 3D drawing and when i edit an isometric it's drawn the wrong way. If i keep editing the isometric again and again it will turn the right way and then the wrong way. It seems to be sensless.
Does anyone know how to fix that?
Damien
This is a known issue and if you do a search you'll see people have this problem too.
The only fix is to flip it once the ISO is produced (in the 2D model)
but this is not the solution on this...
hope, Autodesk will come up with valid solution very early.!! (If it is there, then please let us know. )
The flow arrows insert in the direction you draw the pipe. If you drew the pipe west to east then the flow arrow when inserted will indicate flow is to the east. I have found that if you then try to flip the arrow in the model and run an iso that it will still leave the arrow showing in the direction you drew the pipe. There is no solution to this other than its best to draw pipe in the correct flow path.
I agree with you Blorich when you say we have to draw the pipe in the flow direction. I think it might partially solve the problem.
However, it happened that when I was generating 10 times the same iso:
-7 times, the arrow was from east to west for example
-3 times, the arrow was from west to east
So...
i tried that way.
sometimes it show same direction .. sometimes it shows revers.
we can predict flow direction while extracting iso's for n number of times for same line.
this behaviour is unpredictable.
Logically pipe routing should be from start to end.
but some times we don't know Start point (it might be in explicits somewhere)or some times we stuck up for any reason and at that time we have to route pipe from END position.
AP3D should have that facility / flexibility to route line from both the ends (If Flow arrow is not working as per "reveres of pipe flow / in direction of pipe flow")
