AutoCAD Plant 3D Forum
Working with Spec -Error
2 REPLIES 2
milic.srdjan
568 Views, 2 Replies
When I Try to add to spec, a new
Gate Valve 3/4 " ND, full port, thrd/thrd
from ANSI Valve catalog I get error message...
> "Invalid part property name"
look at picture
Error Property name
But in the same time , system add Gate Valve to spec...In model Valve doest work good...
Milic
2 REPLIES 2
pvicent
in reply to: milic.srdjan
I have the same problem adding fasteners. Can sombody answer this questiom, please?
Thank you
jabowabo
I am able to add the valve to a spec as shown in your screenshot so without your spec and catalog this might be hard to diagnose.  A few questions come to mind:
1.  Is this a migrated spec/catalog?
2.  Have you added any custom properties to your catalog or spec?
3.  Are you using Long Description Styles in the spec?
4.  Have you tried adding the part to a different spec?
”Boost
