AutoCAD Plant 3D Forum
When object has been insterted,next time script works incorrectly
3 REPLIES 3
kudryavcevrm
603 Views, 3 Replies
Please, help me!
There's a simple script:
import sys
import os
sys.path.append(os.path.join(os.path.dirname(__file__), '..', 'CustomScripts'))
from aqa.math import *
from varmain.primitiv import *
from varmain.custom import *
@activate(Group="Support", TooltipShort="Test script", TooltipLong="This is a custom Testscript", LengthUnit="in")
@group("MainDimensions")
@param(aL=LENGTH, TooltipLong="Length of the Cylinder")
def TEST1(s, aL=75.0, ID='P_ACTUATOR_008', **kw):
       aL=float(raw_input("Input text"))
       print "You have been enter:"
       print (aL)
 Look here:
  1. Plant 3D Russian 2013 (Ultimate Suite) SP1, Windows 7 Ultimate
  2. I compile my script using PLANTREGISTERCUSTOMSCRIPT command and restart Plant 3D after this
  3. (arxload "PnP3dACPAdapter.arx")
  4. (TESTACPSCRIPT "TEST1")
Please see my command line log :
Команда: (arxload "PnP3dACPAdapter.arx")
Команда: (TESTACPSCRIPT "TEST1")
Input text78
78.0
<Имя объекта: 7ffff705c00>
<Имя объекта: 7ffff705c20>
As you can see, my friends, when script was executed in the next time in the same session, it keeps aL value.
When we now execute _PURGE command, script will be executed correctly.
How to modify my script???
3 REPLIES 3
kudryavcevrm
in reply to: kudryavcevrm
up
The scripts are meant to create geometry (i.e. a block). To avoid regenerating the same block all the time, Plant 3D first looks up the block table if it already has a block that matches the script parameters. If such a block exists, it will just use it, and not invoke the script.
It looks like in this case, each block shall be unique. I haven’t tried it, but (TESTACPSCRIPT "…" "__unique__" "1") will probably do what is wanted. It will create an anonymous block instead of a block that hashes the parameters.
Marat Mirgaleev
Developer Technical Services
Autodesk Developer Network
Thank you, Marat.
"__unique__" works fine in test mode. But we need to use script in real life, not in test mode only. We need to compile script as unique.
Help me, please!
”Boost
