I modified the ASME catalogue to display the items as SS items instead of CS. I kept all the properties the same, yet for some reason the Flange is showing up as a different type of flange.
Also possible related ssometimes it picks and chooses when to display the fittings in the ISO drawings.
I am still using 2011 as well.
Hello, can you try to look on your catalog editor the flange that you made its Iso Symbol SKEY. See if its FLWN
Thanks I looked at the ISOkey on SPEC editor it had the correct value, but apperently I accidently changed it from FLWN to FLRFWN in the excel sheet which I used to automatically update Spec Editor..
Problem fixed
