Good Morning,
I'm having an issue where the weld maps call outs are not correct on the Iso. There are 3 dimonds pointing to one weld, and another weld that has no dimond pointing to it. In the overall weld count on the weld list there is one extra butt weld per side.
Any suggestions?
Rod
Check your Weld Annotation settings to see if both Shop and Field welds are selected: Project setup/Isometric DWG Settings/Annotations. (See attached image)
And are all the other Weld annotation settings how you want them?
Weld Annotations
http://docs.autodesk.com/PLNT3D/2014/ENU/filesPLNT3D/GUID-0BDB5F4F-520B-4F03-A42C-1EAA8AECB539.htm
(If this answers your question, please mark it as an Accepted Solution.)
Yes, both are checked. The problem is the iso is listing extra welds that are not there.
This problem is easily duplicated, draw a flange, 90 and pipe. Then draw a SOL or TOL on the 90 and run an Iso.
See attached, two butt welds and one tap weld, but 4 butt wleds are listed.
Did you ever find a solution to this? I'm having the weld annotations omitted from isos on TapWelds, regardless of if they are shop or field.
