We are considering buying Autocad Plant Design Suite. One thing that I am specifically looking for is pipe specifications in the 3D software that we use all the time.
Most of the pipe/plant design that we do here are at Pharma plants so we need specs that include the following:
Copper fittings
BPE fittings
Stainless Steel Tri-clamp fittings
SS compression fittings
Hoses
Do these specs exist or can they be made? If they don't not sure we will buy the suite. We use these specs all the time.
Phil
You can download the trial and see what it includes. There are also other Catalogs you can grab from the Plant Exchange website. You can also create your own custom catalogs if required.
