AutoCAD Plant 3D General DIscussion
Distinguished Contributor
Arun_Kumar_K
Message 1 of 7 (742 Views)
Wafer Type valve without Gaskets
742 Views, 6 Replies
11-24-2012 08:15 AM
 We need to model the Wafer type valve without gaskets as the wafer type valve is supplied along with lining (no need of gasket required in this condition), how to do it in Plant3d.
Valued Mentor
Rich.O.3d
Message 2 of 7 (684 Views)
Re: Wafer Type valve without Gaskets
11-26-2012 08:24 PM in reply to: Arun_Kumar_K
make an end type, i use WFL (wafer lined)
set joint properties for FL to WFL to not have gasket
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Arun_Kumar_K
Message 3 of 7 (658 Views)
11-27-2012 04:20 AM in reply to: Rich.O.3d
Checked in Piping end connection, i couldn't find the end connection named WFL. Can u add a snapshot?
Valued Mentor
Rich.O.3d
Message 4 of 7 (655 Views)
11-27-2012 05:32 AM in reply to: Arun_Kumar_K
you have to add the endtype...type PLANTENDCODES, you will be able to add new endtypes
once you have added it, then you go to project props and set up the joint type
CAD Management 101:
Member
atul_0775
Message 5 of 7 (592 Views)
12-03-2012 03:01 AM in reply to: Rich.O.3d
dear sir
i am done all step in P3D but still wafer type valve come with gasket so pls. sugges me as soon as possible.
Valued Mentor
Rich.O.3d
Message 6 of 7 (448 Views)
05-04-2013 05:13 PM in reply to: atul_0775
your simple joints WaferFlanged and WaferWafer are conflicting, you havent actualy defined a joint for a flange to connect to a wafer.
your WaferFlanged joint should have 'End 1' as WFL and 'End 2' as FL
CAD Management 101:
halitomi
Message 7 of 7 (287 Views)
01-30-2014 01:12 AM in reply to: Rich.O.3d
But in this case there will be two bolt connections instead of the one which is the reality in case of wafer type connections.
I have the exact same problem but can not really solve it this way.
Can you give me the method how to set a connection which "requests" wafer type bolts from the database?
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
