AutoCAD Plant 3D General
Distinguished Contributor
Arun_Kumar_K
Message 11 of 92 (4,874 Views)
Re: WISH LIST AUTOCAD PLANT 3D 2015
04-10-2013 07:59 AM in reply to: Arun_Kumar_K
14. Parametric modelling of equipments and supports creation feature in Plant 3d space.
Valued Mentor
ybogdanov
Message 12 of 92 (4,850 Views)
04-14-2013 08:50 AM in reply to: Arun_Kumar_K
15. Reduce ISO generation time in by-pass lines.
16. Posibility to manual define schematic ISO lines, change the length and orientation of elements, before to generate iso.
17. Update ISO and not regenerate, in case if there are changes in 3D.
18. Solve  problem of Stub-in in excentric SWAGES.
19. BOM list in ORTHO views.
20. Posibility to generate isometric-ortho view of one selected line number. (Now is necessary hide all to project one line)
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Employee
PeterQuinn
Message 13 of 92 (4,849 Views)
04-14-2013 08:53 AM in reply to: Arun_Kumar_K
About Weight on isometrics. If you put weights in the model, it will come out in the PCF. Have you tried adding it to the BOM? Does it not work?
Peter Quinn
Senior Product Manager
Autodesk, Inc.
Arun_Kumar_K
Message 14 of 92 (4,840 Views)
04-14-2013 09:19 AM in reply to: PeterQuinn
Sorry, I am not clear with you, would be better if you post with some screen shots,
Employee
PeterQuinn
Message 15 of 92 (4,837 Views)
04-14-2013 09:36 AM in reply to: Arun_Kumar_K
Weight on Iso BOM. I see the topic discussed in detail in another thread. I tried it and see that it's not working. Thanks for the heads up. I'll see what I can do about it.
Peter Quinn
Autodesk, Inc.
attila_vallyon
Message 16 of 92 (4,819 Views)
04-15-2013 03:24 AM in reply to: Arun_Kumar_K
Hi !
I will repeat my requirement what I did for the 2013 and 2014 wishlist.
Hopefully I have better luck next time!
"I want to set up a bent pipe segment. The feature "pipe bend" is good but does not solve my problem completely.
In a bent pipe there is no buttweld at the end of the bends and there should be an overall length for the whole segment.
The purpose of the pipe bent (for the smaller sizes usually) is to bent the pipe without having a separate elbows and buttwelds.
Right now the software generate a pipe bend and I can edit manually the parameters of the geometry. But that is still a separate element with buttweld on both ends."
Thanks in advance!
Attila Vallyon
Arun_Kumar_K
Message 17 of 92 (4,813 Views)
04-15-2013 07:50 AM in reply to: attila_vallyon
Yes, the above requirement is an imperative too. To model tubes inside boilers, the above feature is required.
Employee
JarrodMudford
Message 18 of 92 (4,804 Views)
04-15-2013 12:52 PM in reply to: Arun_Kumar_K
With Plant Design Suite Ultimate, you now have Inventor with Routed Systems. You can produce bent tube models in there. With those models you can produce ybc and xyz files for use with bending machines.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Jarrod Mudford
Plant Solutions Consultant
Global Services
Autodesk, Inc.
attila_vallyon
Message 19 of 92 (4,782 Views)
04-16-2013 01:41 AM in reply to: JarrodMudford
Well,
my company has only the Plant design suite premium plus 2014, but even if I had that I would not want to use Inventor to make the bent pipe. Because I don't know the result when I want to generate ISOs.
I want to use Plant 3D only to make the bent pipes. And right now it is not possible unfortunately.
Attila Vallyon
Arun_Kumar_K
Message 20 of 92 (4,773 Views)
04-16-2013 08:45 AM in reply to: attila_vallyon
To model the whole plant, we might need to use all Autodesk products. From the reply I find, the investment cost of Autodesk product will be less, but the operational cost will be high. we may need highly qualified engineers to perform all the models in different platforms of Autodesk. Nobody ll be in market ouside, who ll be knowing plant3d, Revit, mep, inventor together. I find more justification rather than acceptance. I have faith and need this software to be used everywhere. Otherwise I won't spend everyday apart from my work time here.
You are not logged in.
Announcements
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
